Steps and procedure to uninstall developer Mac from our PC
What are the correct steps and procedures involved to uninstall developer mac from our PC without disturbing other programs?
Hello Abraham. To uninstall developer from your mac without disturbing other softwares, all you have to do is to copy the command below and paste it in your terminal window and then hit the enter button:
sudo/Developer/Library/uninstall-devtools-mode=all
This will uninstall all developer tools from your system.
You may have to provide your password as well.
Hope it worked well.
Samuel
Its simple and very clear, follow the steps in these link and get working well with your machine.
You can also try to type the following command in the terminal sudo/Developer/LIbrary/uninstall-devtools-mode=all But be sure the X-code will be gone and gone completely but you can reinstall it again so don't worry.
