Kyle Berry
30 points
Posted on - 11/16/2012
Hi everyone,
How to perform adobe elements 6 change language? Changing some default languages in a specific setting is not that easy especially to an unfamiliar application. I am not that good in researching that is why I need some help from the experts. Give me your best answer.
Steps on Changing Adobe Elements 6 Language
Hello Kyle Berry. It won't be easy navigating to and fro on adobe element 6 trying to change the language. The best option is to download the installation file in the language you are familiar with and install it from the scratch. This will definitely fix the problem. You can download a copy here:
http://download.cnet.com/archive/3000-2192_4-10759148.html
Make sure you download the English version.
Thank you.
