Steps in Converting Exe Files to Cab Files For Pocket Pc
How could I convert Exe Files to Cab files in my pocket Pc? I want an easy instructions to do this.Â
Hi dear Jordon Troutman,
There might be some ways to do the job.
But i think convert the files online is the best idea.
I highly recommend these because its less time consuming as well as in this process you will not find a single problem.
So i think its best idea to do as i stated in my answer.
Please visit the following site youconvertit
Just open the website and upload your desired file. Later on, it will convert the file in a shortest possible time.
After that you can download the desired file from the website.
Its a easy and simple process rather than manual methods.
