How does one transition from CRM 4 to CRM 5 without possible uninstallation to avoid loss of data, and what are the additional dynamics and features that CRM 5 will have over CRM 4 that Microsoft promises?
Steps for crm 4 to crm 5 transition and additional features
Hellow,
CRM 4.0 can log plug-in can be used either prior to the date of the event (to me) with the preceding or following operations occurred: customer relationship management platform (dimensions). However, you will not be able to perform as part of the same movement, which has the right to compensation logic if the operation failed because the CRM platform. To work around this limitation, you can now save plugin program solves CRM5 as part of the. How to register the component has been modified to support this CRM5.
Regards
Franke Mary
Hellow Robert Martin,
I am telling about new feature of Microsoft CRM 5
It introduces the Ribbon tab different for different menu.
In CRM 4 you might have problem regarding tab selection .This has been removed in CRM 5
It has the grid views which can perform filtering data with a single click.
You can now customize your form layout for positioning fields in your CRM 5.
The items can be moved by dragging and dropping in a moment
Thanking You
Shifflett Laurel
