Hello. I heard about this Cleartype Font Handwriting. If I am not mistaken in understanding it, you can actually make your own handwriting as the font of your text files. Now, I am really interested in doing this font so I need your help in doing the easy step-by-step in achieving this font. Your help will really be appreciated, thank you in advance!
Steps in doing Cleartype Font Handwriting
Hello Willu,
How to install and use your handwriting font
Please check the link, where they will show you
step by step tutorial about the software. It is very easy to use.
Installation process.
Appearance improvement (On screen & on paper)
Add you signature.
SPACE anchor system
Capitalize software
BackupÂ
Email messaging by using your font.
Web page designing by using your font.
etc.
Hope this will help you.
Thank you.
First, use their online service and from there you can submit your own handwriting. The service will create for you the accurate font that you want. However, charges are applied in using their service and it is the only way to deal with the situation. Send them your email account and wait for them to send your font file.
1. You can save your fonts on your Windows/Fonts directory
2. By going to Control Panel > Fonts > Install Fonts > Locate it
3. Double clicking the font file to automatically install it
