Steps For Efax Messenger 4.4 Free Download
Hi. I want to know the steps which need to be followed for efax messenger 4.4 free download. Also, what are the pre-requirements and the features? Please reply ASAP. It is urgent. Thanks in advance.
Hi. The system requirements are Microsoft Windows 7, 8, XP, Vista, and OS X. The file size is 1.1 MB for OS X and 3.6 MB for all the other Windows versions. Its features are-
1) It can be used to view, edit and store the faxes received
2) It can sign a document legally using digital signature
3) It can be used to convert the fax to PDF
4) It can be used to save and see the faxes sent
The steps for installing the efax messenger 4.4 free download are-
1) First, you need to create an account on efax messenger
2) Then, you need to select the version of the messenger which is the most suitable for your PC’s operating system
3) Select the download option
4) The file should then be saved in the computer itself
5) After the file gets saved, follow the instructions displayed to install the software by double-clicking on the saved file
6) After the installation completes, there will be an icon present in the program menu(Windows) or in the applications folder(MAC) which can be used by clicking on the icon
Hope we helped
Notifications
