De Castro 0 points N/APosted on - 07/28/2016
Hi.
My Samsung note is not working properly from a few days. Can you please help me by suggesting the steps for the factory reset Samsung Note 3? Also, what are the steps for the hard reset of Samsung note 3? Thanks in advance. It will be very helpful.
The Samsung Galaxy Note 3 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was announced to the public and released on September 2013 measuring 151.2 x 79.2 x 8.3 millimeters and weighing 168 grams. It uses micro-SIM card and is built with plastic body.
It has Super AMOLED capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass 3.
It runs on Android 4.3 Jelly Bean upgradable to Android 4.4.2 KitKat and Android 5.0 Lollipop powered by Qualcomm Snapdragon 800 chipset for the N9005 and N9002 models and Exynos 5420 Octa chipset for the N9000 model, 2.3 GHz Quad-Core Krait 400 processor for the N9005 and N9002 models and Octa-Core (4 x 1.9 GHz Cortex-A15 and 4 x 1.3 GHz Cortex-A7) processor for the N9000 model, and Adreno 330 GPU for the N9005 and N9002 models and Mali-T628 MP6 GPU for the N9000 model.
It supports microSD expandable up to 64 GB. It runs on 3 GB RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 13 megapixels with f/2.2, 31mm, 1/3″, 1.12 µm, LED flash, and autofocus featuring face detection, HDR, panorama, geo-tagging, and touch focus.
It supports 2160p video recording at 30 fps and 1080p at 60 fps for the N9005 and N9002 models and 1080p for the N9000 model. The secondary camera supports 2 megapixels with f/2.4, 27mm, and supports 1080p video recording at 30 fps.
It has 3.5-millimeter jack featuring 24-bit/192kHz audio and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, and LE support; GPS with A-GPS and GLONASS support; NFC; infrared; and microUSB 3.0 with MHL 2 TV-out and USB Host support. It doesn’t have FM radio.
It has built-in accelerometer, gyro, proximity, compass, barometer, temperature, humidity, and gesture sensors. The pre-installed web browser supports HTML5. It runs on removable Li-Ion 3200 mAh battery with standby time up to 420 hours on 3G and talk time up to 21 hours on 3G. It is available in black, white, pink, merlot red, rose gold black, and rose gold white colors.
Now, to factory reset your phone, turn off your device completely. Next, press and hold the Volume Up, Home, and Power buttons simultaneously until the “GALAXY Note 3” logo appears. When you see the logo, release the Power button only and continue pressing the other buttons. When the “Android System Recovery” menu appears, release the remaining buttons.
Navigate through the menu using the Volume Up and Volume Down buttons and select “wipe data / factory reset” and then press the Power button once to execute. On the next screen, select “Yes — erase all user data” and then “reboot system now.” Note: before factory resetting your phone, copy all your contacts to your SIM card and back up your other phone data and then remove both your SIM card and memory card from the device.
1....
