Steps To Follow To Know How To Allow Remote Desktop Connection
Hi. What are the steps needed to be know how to allow remote desktop connection? Please reply ASAP. Thanks in advance.
Hi. To know how to allow remote desktop connectionon the computer are as follows-
1) Click on the start button
2) Right-click on my computer and click on properties option
3) Select the remote settings option
4) Type the password if asked
5) Click on the select users option
6) Select theAdd option in the remote desktop users dialog box
7) Enter location and object names in the remote users dialog box and click on OK The steps to allow desktop connection through Windows Firewall-
1) Click on start menu and click on control panel option
2) Click on the system and security option
3) Under Windows Firewall, click on Allow a program through Windows Firewall option
4) Mark the option next to Remote Desktop and click on the change settings option
5) Click on the OK option
Hope we helped.
There are different ways how to perform a remote desktop connection. One is using Avast antivirus. Remote management is a feature built-in to the Avast antivirus and is not downloaded separately. It is only useful if the other computer, where you want to connect to, is also using Avast. But if not, you won’t be able to use the Remote Assistance feature.
The “Avast Remote Assistance” feature works by creating a secure remote desktop connection so you’ll be able to help your friend with any computer-related problem. You can connect to the other computer by adding other known devices to your Avast account or using a unique code. The person on the other computer must accept the request to connect successfully.
It doesn’t require installing any remote desktop application because it is already built-in to Avast. All Avast security products have the Remote Assistance feature and this includes the free antivirus. To use this feature, on the computer that needs help, click “Allow Remote Control” on the Avast interface. After this, Avast will generate a code needed for a successful connection.
Send this code to the person on the other computer who will provide the assistance. When the person receives the code, on his computer, click “Control Remote Computer” in the Avast interface. Enter the code then click “Connect”. When the connection has been established, the dialog disappears and the remote desktop window appears.
When the person is finished fixing the problem on the other computer, you can terminate the session by pressing ALT + SHIFT + End. Just an additional note: when sending the code to the user of the assisting computer, Avast suggests doing it by telephone, email, or chat to make it more secure. Download the latest version from Avast Free Antivirus.
