Steps To Follow So As To Learn How Do I Get Javascript
Hi. I would like to know the steps to be followed so as to learn how do I get JavaScript. Please give the steps for IE as well as Mozilla Firefox. Please reply ASAP. Thanks in advance.
Hi. The steps as to how do I get JavaScripton IE for Windows are as follows-
1) Click on tools and then select the internet options. The internet options dialog box will appear which will show you the options to set the browser preferences
2) Click on privacy menu so as to enable the session cookies
3) From the settings menu, click on advanced option
4) Check mark the option always allow session cookies
5) Click on security to enable JavaScript
6) Select the custom level option after you locate the custom area in security
7) Amongst the security settings select the option Scripting
8) Check mark the options enable active scripting and scripting of java applets
9) Close the security settings window after clicking on OK to accept the scripting and cookie handling changes
10) Click on apply in the internet options dialog box that appears and then click on OK to close the dialog box
The steps as to how do I get JavaScripton Mozilla for Windows are as follows-
1) Open the edit menu in Windows and then click on preferences
2) Click on privacy & security from the category menu
3) Click on cookies
4) Select the option to enable all cookies from the cookies page
5) Click on open the advanced category from the category menu
6) Click on scripts & plug-ins
7) Check the option of navigator and then locate the enable JavaScript section
8) Click on OK and close the preferences dialog box
Hope we helped.
