Hello everyone, I was working on the system when a dialog box appears says Amazing slow downer error 139. Since I was completely unaware of the mistake I closed the dialog but it didn’t stop blinking on my screen, and it’s very annoying. Kindly suggest me some process through which I can solve this error.
Steps For Amazing Slow Downer Error 139 Fix
The manual process:
Start your system as Administrator.
Select start menu and navigate to programs then accessories.
Choose system tools and click on system restore.
Choose the option “Restore my computer to an earlier time” and select next.
Select the latest among the following one.
Hit Next button for the confirmation window.
Restart your system.
That error was from “Amazing Slow Downer,” a program that’s designed for musicians wanting to slow down music without altering the pitch. Just try to uninstall and reinstall the program. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select Amazing Slow Downer among the applications and click “Uninstall.” Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This will remove everything the program created on your computer. When it is finished, close Revo Uninstaller then download the free version of CCleaner and install it. Once installed, start CCleaner and clean your system. When it is finished, close CCleaner and install Amazing Slow Downer back.
See if this works. If you are a registered user, you can download the latest Amazing Slow Downer. The latest version at the moment supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. If you want to convert CCleaner to Pro, download the codes and follow the instructions.
