Steps For ‘how To Increase Volume On Laptop’
Hi! I recently purchased a laptop for the first time. Can you please tell me how to increase volume on the laptop?
Steps to increase the volume of the laptop-
If you have a laptop, there are two (2) ways how you can increase the volume. First option is within Windows using the volume icon or the speaker icon located on the system tray. To try this method, click the volume icon on the system tray to display the volume slider. Now, just move the slider up or down to change the volume.
The second option is to use the volume button (+ and -) on your laptop. It is usually located just above your keyboard on the upper right corner of your laptop. Check the sides or corners of your laptop for plus (+) and minus (-) symbols or buttons which indicates the volume function.
But for this to work or for you to be able to change the volume, your sound card driver must be installed. You can download the sound card driver from the following manufacturers:
