Steps For ‘how To Open InPrivate Browsing On Internet Explorer’
I have to open some important documents related to my work in Internet explorer because last time, somebody traced the browsing history and copied the important data of the company. But the issue is that I don’t know how to open InPrivate browsing on internet explorer. Can you provide the steps for it?
Answered By 0 points N/A #324872
You can open InPrivate browsing very easily on Internet Explorer with the help of these steps-
  • Open Internet Explorer on your PC.
  • Click on the ‘Settings.’
  • Select ‘Safety.’
  • Click on the ‘InPrivate Browsing.’
This was the manual method. You can directly activate the InPrivate browsing of the Internet Explorer by pressing Ctrl, Shift, and P keys together on your keyboard.
You can also activate it by right-clicking on the Internet Explorer icon present on the taskbar of your PC screen and then by selecting the ‘Start InPrivate Browsing’ option.
