Steps For MS Windows Server 2008 R2 Installation
Hello, what are the supported OS for ms windows server 2008 r2 also mentioned the steps to install the same for the easy understanding. Thank you.
Hey the supported OS for ms windows server 2008 r2 are in only 2 Os’s i.e. Windows server 2008R2 and windows 7 only. As it is supported only in this to OS and gives good performance for the same also when installed on the specific OS. following are the steps to install the same:
• First click the continue button and downloaded the process by selecting than languages and click on GO.
• You can make the download later or immediately depending upon you requirements.
• To start the downloading immediately click open > run > location.
