Steps For Outlook 2007 Remove Duplicate Emails In A Stepwise Manner
Hello, notify the steps in outlook 2007 remove duplicate emails as stepwise for the better reference only. Reply ASAP and thanks for the same.
Hey, find the below steps for outlook 2007 remove duplicate emails as follows:
• First open outlook 2007 > view menu and click for change the folder view.
• Next right click the heading > filed chooser.
• Next select all the item name fields.
• Later drag the modified field to table headings as well.
• Next verify the items and if its unique then click for the modified heading.
• Next delete the first item if you wish so and then click for the last one while pressing the shift key
• Lastly delete it permanently.
Notifications
