Hello everyone, I got some of the useless add-ins in my Outlook. Now every time I am seeing it I want to remove them. Is there any way for Outlook 2010 disable add-in? I am currently working on Windows8.
If you use Microsoft Office Outlook as your email client and you want to remove or disable permanently the add-ins, here’s how to do it. Start Microsoft Office Outlook then click “File”, “Options” then “Add-ins”. On the right, go to the bottom of the window and look for “Manage”. Click “Go” next to it. In “COM Add-ins” dialog, select the add-in you want to disable or remove.
Microsoft Office Outlook disable or remove add-in
If you simply want to disable it, just uncheck the box before it then click “OK”. But if you really don’t need it and you want to uninstall it, select it on the list then click “Remove”. When you are finished, click “OK” to save the changes. And that’s it.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
