Steps For Setting Up Wireless HP Printer
I have purchased a new wireless HP printer, but I am having some trouble installing it. Can anyone tell me how to setup a wireless HP printer? Please explain with the help of steps.
The steps for setting up a wireless HP printer are:
1. At first, unpack your printer.
2. Now, you have to plug in the power cord, turn the printer ON as well as install print cartridges. Then let the printer to go through its start-up schedule, which includes printing an alignment page.
3. Select one of the connection process described below. Choose an Ethernet or wired connection if your printer support it, connect it and now install the printer software. (IMPORTANT: Disable the printer’s wireless system an Ethernet connection using time.)
Notifications
