Steps For The Old Camcorder Tapes To Dvd In Stepwise Process
Hello, notify the steps for old camcorder tapes to dvd in stepwise for the easy reference only. Reply ASAP for it and thanks for solving.
Hello, below shows steps for old camcorder tapes to dvd as follows:
• First connect the camcorder to the DVD and then switch it on
• Next plug-in the audio and video wires to the camcorder respectively to the back of the DVD
• Now put the camcorder and a single blank tape for copying on the DVD
• Later press the play button on camcorder and record on the DVD simultaneously
• Stop both sides after the recording is over.
• After the successfully coping try truing the DVD and view for the same.
