Steps For The Restore And Backup Windows 7 And Its Brief
Hello, notify the steps for restore and backup windows 7 and mentioned the same in brief as well and thanks for solving and reply ASAP too.
Hey, the restore and backup windows 7 can be done on the same systems or can be done manually for the other systems as well. Also the same features are present for all the windows OS as well and can be done easily as it’s not a difficult job too. Below shows its steps as well:
• First click on the start button > computer
• Now double click for the files and save in the drive you want.
• Next also same do it for the users folder by double clicking it
• A separate folder is made in the user account too
• Then open the folder to create the backup and restore the files simultaneously as well.
