Steps For Trend Micro Uninstall Tool Listed With Solution
I need help with the trend micro uninstall tool as I am not getting how to uninstall it or use it. Please someone help me out with it as I am in a fix here and can’t find any solution for this.
Answered By 20 points N/A #300590
To uninstall trend micro, follow the steps below-
  1. Download the uninstall from the link-
http://solutionfile.trendmicro.com/SolutionFile/Security_Software_11/Tools/Ti_110_win_en_Tool_UninstallTool_hfb0002.exe
  1. Run the exe file
  2. Click yes in the next window that appears
  3. Click on I accept the agreement and then next
  4. Then install and then ok
  5. Then click on uninstall software
  6. Then you need to enter the captcha
  7. Then click uninstall and then yes to restart the computer.
Answered By 590495 points N/A #302305
If you have a stubborn program that doesn’t want to be removed, one solution is to uninstall it with Revo Uninstaller. Go to Revo Uninstaller Freeware and download the free version. Once installed, start Revo Uninstaller then select your Trend Micro Uninstall tool from the list. Click “Uninstall” then follow the instructions. This will remove everything the program created and backed up on the computer.
When it is finished, restart your computer. Basically, when you click “Uninstall,” Revo Uninstaller will first initiate the normal uninstall process by running the uninstall program of the Trend Micro Uninstall tool. Here, just follow the normal uninstall process. In case this part fails, click “Forced Uninstall” instead to forcibly uninstall the program. When uninstall is complete, click “Scan” to scan your computer for remnants.
When the scan is complete, click “Select All” to select all items found and then click “Delete” to delete them from your system.
