Steps For Windows 7 Pro Volume License Agreement
Considering down grading or upgrading the devices to Windows 7 Pro Volume License? Make sure that you know the steps before moving forward. What are the points you need to know initially?
when you are to shift your devices to other Windows, you should get the appropriate licensing agreement. Such that, if you need to buy Windows 7 Pro Volume License, you must have or going to use for Windows 8.1 Pro Enterprise Upgrade.
Very importantly, your device should already possess an operating system installed in it, before you upgrade or downgrade. Note that bits of the bought version should match the systems, such that if 32-bit system is used, a Windows 7 of 32-bits should be accepted, else you can’t expect it to suit your system.
So, installation bits are equally important as the version is.
Notifications
