Steps As To How Do I Print Photos From My Phone
Hi. I want to know how to print photos from my phone. Please let me know the steps to know how do I print photos from my phone. Thanks in advance. Please reply ASAP.
Hi. The steps to follow to know how do I print photos from my phone are as follows-
1) If your printer has Wi-Fi connection, then it is said to be cloud ready. Even if the printer is turned off, the printer can connect to the android device.
2) Open the browser
3) Open the menu and make sure that you are signed in the Google account
4) Click on settings. Select the show advanced settings and then click on manage
5) This is where you will link the printer to your Google account
6) Select the add printers option and then check mark the option for the printer from which you would like to print. Click on add printers again
7) Then, next set up the android device
8) Open Chrome, then from the menu of the app, click on print. Select the printer from the list and select the paper size and color. Then, click on print.
Hope we helped.
