david1234
20 points
Posted on - 07/20/2011
I was working on computer and mistakenly I deleted my very important file. It was also not present in recycle bin. Can anybody please guide.
What steps should I do so that I may get my file back?
Even I tried different software’s for getting deleted files back but none of the software is working.
Can anybody help me through this?
recha
Steps on How to Recover Deleted Files
Dear David.
The thing is that your data has been deleted even after installing recovery software you never recover your original data because the software you are using actually the problem is with your software which you had installed. Now you are suggested to go with the solution given below
You are highly recommended to purchase a well reputed recovery software, which can help you recover your data.
Recha.
enarque
Hi!
There are many tools readily available that can help you recover your deleted files. Software evaluation studies show that the UNERASER is the best deleted files recovery software that can be used for Windows. This software employs in-depth search method and state-of-the art recovery algorithms that makes it possible to get back the lost files.
Compared to other undelete software available, this product is equipped with powerful tools, such as thumbnail preview, which facilitate the immediate identification of your deleted files.
Hope this helps you in getting back your important file.
David,
You have not stated there what can of file is that but then if it's a software where you installed at that time then have mistakenly deleted you can use the restore point which is accessible in windows system tools. I've tried this many times whenever I have deleted some important soft wares.
Just choose the date where you want to restore or maybe I should say it'll roll back the files from where the date you restore.
There a few programs that will claim to recover your deleted files on your computer, however with many shareware that were going to download and will not harm your computer as well.
And this is how to solve your problem…
Step 1.
Download the Panda Recovery
Step 2.
Install it in your computer and run the program.
About the program: It allows you to recover the deleted files in your computer even if you accidentally delete your important files, such as pictures, movies, songs. and it allows you also to find and recover deleted files in NTFS-format.
Hope it will help you, enjoy.
David,
As you have stated your problem, that you have deleted certain important files so if it's a software where you installed at that time then have mistakenly deleted you can use the restore point which is accessible in windows system tools. I've tried this many times whenever I have deleted some important software. Just choose the date where you want to restore.
Hope you can help to this simple steps.
Yongrak
30 points
Hello! David1234,
About your problem i just want you to download the software called "Handy Recovery" I use that software until now and it works well then all you have to do is to look for that software. Then you are lucky if you have that software. Then I want you to know that if you accidentally deleted that file for your information that all the files in your hard drive could recover for example; you choose the drive C: then all files that are been deleted will be recovered. But if your hard disk drive had a bad sector it might not recover some other files on it.
Now if you already run the software it will give you folders then look inside and find your file you've accidentally deleted. Then now you're on your own.
Good luck.
