Steps in importing spb wallet to Mac
I need the steps in importing spb wallet to mac? I’ve customized my wallet and I want the same transferred from my windows mobile to my imac, exact data including templates. How do I go about this to make sure that everything remains exactly or almost the same at least? Thanks!
Answered By 0 points N/A #131491
Hello Robin,
I can understand the feeling of losing some contacts. To help, I suggest you save your spb files on the phone as .csv files. These can then be exported the Mac without much hustle. I see that you have customized fields and while this is a bit complex try to connect your phone to the mac via USB in Mass Storage mode, open the files and save your files. This can only be done when using the 2.1 version.
Expert
