Steps To Know How To Backup Computer On External Hard Drive
Hi. What are the steps to learn how to backup computer on external hard drive? Please reply as soon as possible. Thanks in advance.
The steps which need to be followed as to how to backup computer on external hard drive how to backup computer on external hard drive are as follows-
1) On Windows-
• Get a backup drive in the USB device
• Click on the Start menu, then type backup and click on backup and restore
• Select the set up backup option. Click the external drive which you have plugged in and select next
• Then, click on the Save settings and run backup option.
2) On Mac-
• Plug in the USB drive
• Then, click on the use as a backup disk option. You can click on System preference option following which you can select on time machine
• Then click on select disk backup and choose the external drive from the options provided
Hope we helped.
Notifications
