Steps To Learn About How To Backup iphone Contacts
Hi. I am an iPhone user. I want to save all my contacts and create their backup copy but don’t know the procedure to be followed. How to backup iPhone contacts? Please reply ASAP. Thanks in advance.
Answered By 10 points N/A #119377
The steps to know how to backup iPhone contactsare as follows-
1) Method-1
• Download and then install the Syncious iPhone Transfer application
• Connect the iPhone to the computer by plugging in the iPhone to the PC
• Backup the contacts of your iPhone in the PC
• Click on information option
• Click on contacts icon from amongst all the options provided
• There will be options provided from which you can choose-
-New: Enables you to create new contacts
-Delete: Enables you to remove any contacts which are not needed
-Backup: Enables the transfer of data from the iPhone to the desktop
-Recover: Overwrites all the current existing iPhone contacts
2) Method-2
• Download and then install iTunes software
• Launch iTunes on the device after connecting it to the PC using a USB cable
• Click on iPhone and then select the info option
• Ensure that the sync contacts option is selected
• Click on the backup option after right-clicking on the name of the device
Hope we helped.
