Steps lion switching to Snow leopard for Mac Book Pro
I want to switch from Lion to Snow Leopard. Please provide the steps for lion switching to Snow Leopard.
Dear user,
Follow these steps and you will switch your Mac Book from Lion to Snow Leopard:
1) First of all insert the Snow Leopard disc into your Mac, now restart and C to boot your DVD drive on your Mac.
2) Installation will now start, go to "Utilities" on the menu bar, select Disk Utility”.
3) Navigate Lion to the partition tab by selecting it in the drive in which it is installed.
4) Under the Partition Layout, click on the menu, select "1 Partition", click "Apply".
5) Navigate to Erase tab,select "Mac OS Extended", hit erase, all data on the drive will be deleted.
6) Now proceed with the install by quitting Disk Utility. Now restart your Mac, press long C to boot your DVD drive.
Hope this will help you.
Thank you.
