Steps for Office 2007 setup update
One month ago, I installed Office 2007 in my laptop. Now my Office is running in compatibility mode and requiring for update. Where can I find Office 2007 setup update?
Hello.
The only way for your problem is to buy a original ms office 2007 from its official website.
Click on the below link to go to the official website.
Thank you.
MS office 7 is yet the most powerful and smooth to work with. Once you setup 2007, then it wants an update. MS office 2007 is fine and easy to use. Its update is not that necessary. You can work fine without an update.
https://products.office.com/en-in/download-office-2007
Click on the link. It shows you the complete process.
This link also can help you to setup update.
Hi Michael A Washington,
After some time of using, you find that your office needs to be updated. I recommend that you should download updates from Microsoft Office official website. Here is the link: http://www.microsoft.com/en-us/download/details.aspx?id=5
Another choice for you: you can upgrade to Microsoft Office 2010. Compare with Office 2007, Office 2010 has some new features:
Save document as a pdf file
Preview your document before cut and paste
New effects for editing text and image
New animation and transition for Power Point …
Hope this helps
