Steps to remove clone cd installation data from my PC
What steps do I need to follow in order to completely remove clone cd installation data from my personal computer so as to avoid a frequent pop up requesting for updating the application?
Many people like to use some Clone CD to manage their business. If you no longer want to use the program and do not need the data the application contains, you can uninstall Clone CD by two ways it is also fact from the system's CP (user control panel) help of your computer (PC) it could be solved, from the add and remove programs which leads to UN-installation.
If you want to remove or uninstall an application from your computer, the easiest way is from the Control Panel using the “Add or Remove Programs” applet if you are using Windows XP. This applet has a different name in Windows Vista, Windows 7, Windows 8.x, and Windows 10.
Though this is the default way of uninstalling applications in Microsoft Windows, there are times it leaves entries in the Windows registry created by the application. If you want a complete removal of the application, the best way to do it is with third-party applications like Revo Uninstaller. To try it, download the free version of Revo Uninstaller and install it.
Once installed, start Revo Uninstaller then select your program or Clone CD among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then download the free version of CCleaner and install it.
Once installed, start CCleaner and clean your system. When it is finished, restart your computer.
Notifications
