Steps To Replace Dell Precision M90 Video Card Replacement
Hi. I have been facing the issue of a video card from quite some time now. I think it is due to overheating. I just want to know the steps for Dell precision m90 video card replacement. Kindly help me with the same. Thanks in advance.
Answered By 0 points N/A #161437
Hi. The steps for Dell precision m90 video card replacement are as given below-
1) First, switch off the computer
2) Unplug all the electronic devices connected to your PC
3) Now, remove the pivot
4) The keyboard needs to be removed
5) The display assembly and the palm rest have to be removed after removing the keyboard
6) Now, the four screws which connect to the system board should be loosened
7) Thermal cooling assembly should be removed after being lifted
8) The new thermal protection should now be placed o the thermal-cooling assembly
9) The processor thermal-cooling assembly should be placed on the top of the processor
10) The four screws which were loosened should now be tightened to support the new video card
Hope we helped
