What is the remedy for me to restore back my play store when I delete it? Is there a way to go about it apart from resetting my phone to factory settings? I am using an android smartphone and I left the phone on the sofa bed to the kitchen to fix up a little beverage only to return to find my kid brother playing with the phone. When I took it from him, he had deleted a lot of apps including my play store app on the phone within that short time. I do not know what to do now. Please help me. Thank you.
Steps to restore play store app without factory settings
Hello Ronnie,
Sometimes Google play got disabled and in menu it doesn't appear sometimes. At that point of time you need to go through application manager from settings, and go to ALL, search Google play is there or not. If its there means it is in disabled state. Make that enable and play store will be again on your menu at your service.
If you do not find play store on application manager then you need to download the apk file that is the installation file of play store from internet.Some of the suggested links are
http://www.mediafire.com/file/8rjwcrsapbyuj0e/com.android.vending-4.6.16.apk/file
https://androidfilehost.com/?fid=23329332407578662;
And there are other links also which you can find from Google. After downloading copy the APK file to your memory card on handset. Install the APK and play store will be present again in your phone menu.
Derick Harris
Hello Ronnie,
Derick Harris
