I have just started using Microsoft Powerpoint to create a presentation for work and now I am having trouble adding pictures to it. It would be great if you could help me understand how to add Microsoft PowerPoint pictures to make my presentation more interesting. Thanks in advance.
Steps to add Microsoft PowerPoint pictures.
Hey! Once you have opened Microsoft PowerPoint Presentation, open the slide in which you wish to insert the desired picture. Go to the Insert tab and select picture command from there.
An insert picture dialog box will appear after you click on the picture command. You can choose the desired picture from the files on your system. Once you select it, click on the open option on the bottom right-hand corner of the dialog box, and the desired picture would appear on your current slide. You can refer to the images for a better understanding of how to add Microsoft PowerPoint pictures. I hope this helps.
