Steps To Check Genuine Microsoft Windows 7 Validation Method
Diano hartyu 0 points N/APosted on - 07/14/2017
I want validate my copy of Windows but I don’t how to do so. I have tried various methods but still it did not get validated. People help me with genuine Microsoft Windows 7 validation. Thank you.
There are two methods to validate your copy of Windows-
Go to settings and then go to updates and backup section. In that look for activation. In activation click on activate and it will be validated or else angry a new product key validate it.
The other method is to validate online. Go the link given below on the pc which you want to validate and it will automatically validate your OS
If you have Microsoft Windows 7 installed on your computer but you are not sure if it is genuine or not, there are different ways to validate the authenticity of your operating system. The first method to validate Windows 7 is from within the operating system itself. Click “Start” then in the search box type without quotes “activate windows” and then click “Activate Windows” from the results.
Search activate windows
If your Microsoft Windows 7 operating system is genuine and activated, you should receive a dialog saying “Activation was successful” with the Microsoft Genuine logo on the side.
Microsoft genuine logo
Another way is to do the validation online by visiting Genuine Microsoft Software using Microsoft Internet Explorer otherwise it will download a small program when you click “Validate.” The third option is from the Control Panel. Click “Start,” “Control Panel,” “System and Security,” and then “System.” Scroll down until you reach the “Windows activation” section.
It should display “Windows is activated” plus the Product ID as well as the Microsoft Genuine software logo.
1....
