Steps To Create Pivot Table In Excel 2007 Tips
I need steps to create pivot table in Excel 2007 urgently. Since a longĀ  I have been working on it but I am not finding the right option. Please help.
Image result for pivot table in Excel 2007
Answered By 40 points N/A #299374
Steps to create a pivot table-
  1. Select a cell on the data sheet where you want to see the pivot table.
  2. Select insert tab from toolbars
  3. From pivot table button select pivot table from pop up menu
  4. In the crate pivot table window that appears select the range of data and then click ok.
Your pivot table is created.
