Steps To Fix Error Code 30016 25
What should I do to fix error code 30016 25? Why does this bug happen and what is the simplest way to tackle it? It occurs primarily when I try updating MS Outlook or any other MS Office applications.
Solution 1: You must deactivate firewalls and disable anti-virus.
To disable antivirus:
Solution 2: Fix it using System file checker (SFC):
Solution 3: By using the Registry editor.
Error code 30016 25 also occurs because of corruption of registry key values and you can fix it by deleting these key values. You can achieve this by performing the following steps:
Delete all the keys related to Microsoft office and update the values of the following keys from 0 to 1, and they are- LicenseServers, LicenseServerRedirection, AutoExpandDLsEnable, and PassportAuthProvider.
Thanks and regards.
You may encounter error code “30016-25” when you want to renew your subscription to Office 365. When you receive this error on renewing your subscription, you don’t need to download Microsoft Office again. You just need to log on to your Microsoft account and renew your subscription. Your subscription is set up for recurring billing by default.
But if you prefer to renew manually, go to Office 365 Renew page. Next, select the subscription you want to renew then select one of the following:
After this, review your shopping cart then select “Checkout”. On the next screen, log in to your Microsoft account. Next, review your order then click “Renew subscription”. Go to “Manage subscription” to go to your “Microsoft account, Services & subscriptions” page. Here, if you want to renew manually, click “Turn off recurring billing” if you see it to turn recurring billing off.
If you see “Turn on recurring billing”, it means recurring billing is already turned off. But if you don’t see “Turn off recurring billing” or an option for “Cancel” and you see “Paid with” and “None”, it means your subscription will end on the date indicated in “Expires on”.
Notifications
