Steps To Fix Runtime Error 216
Explain each of the steps to fix runtime error 216 and attach the screenshot of the necessary steps.
The runtime 216 error occurs when you open up an application, and it is caused Subseven Trojan Virus, which comes on your computer. This error should be fixed because it can cause hazards to the computer, and it can be fixed by using antivirus.
The steps to fix runtime 216 error are as follows:
• Start the computer in safe mode.
• Scan the computer fully by the antivirus.
• Registry cleaning with a registry cleaner.
Runtime 216 error occurs when one of the two windows does not load a program. This error also occurs when you boot your computer with the Windows Operating System. It can also occur while opening your browser because the trojan virus effect the system and cause problem very fastly.
