Steps To Fix Windows Error Code 0x0000225
What is windows error code 0x0000225? And why am I getting this error on my PC? What is the number of solutions, and what are they to fix this error? What are the necessary steps to get rid of this error?
Answered By 10 points N/A #320210
This error occurs when you Pc cannot find the correct files for booting. This means that the boot configuration data may be corrupted or are infected. Maybe your disk files have dangerous configurations because of these reasons you get the error 0x0000225. There are several answers to this problem such as:
Solution 1: you can use the automatic repair of windows.
Turn your computer off and inject installation media, if you insert a CD or DVD you will get advice like Press any key of your choice to boot,
then you can choose your language
and click on “Repair your computer”
Then you can click on the trouble shooting>Advanced options>Automatic repair.
Solution 2: You can perform an SFC scan on your computer.
Open the command prompt and write the following command.
Solution 3: you can rebuild the boot configuration data which has been corrupted.
Solution 4: you can set active partition.
Solution 5: you can use the system restore.
