Steps To Fix Windows Error Recovery PC
I cannot boot into Windows so how to fix windows error recovery? The normal startup is not working so how do I solve it?
If you have a problem booting your computer, try booting using the last known good configuration setting. Start or restart your computer then press F8 before the Windows logo appears. In “Advanced Boot Options” screen, scroll down and select “Last known good configuration” then hit Enter. This will boot the computer using the last known good configuration setting that worked.
If this doesn’t work, try using the System File Checker utility in Safe Mode since you cannot boot the computer normally or in Normal Mode. Again, start or restart your computer then press F8 before the Windows logo appears. In “Advanced Boot Options” screen, scroll down and select “Safe Mode” then hit Enter. Log in with an administrator account.
Once you are logged in in Safe Mode, press the Windows key + R to bring up the “Run” dialog then type without quotes “sfc /scannow” then hit Enter. Insert your Windows installation CD or DVD when you are prompted then continue. Wait until the process is complete. When it is finished, restart the computer and boot normally. See if this works.
