What are the steps to fix windows update error 800700e? What does windows error 800700e mean?
Steps To Fix Windows Update Error 800700e
This error arrives when you try to search for an update. If the windows update store files are corrupted, then there are chances that this error may arise.
There are various methods in which you can fix 800700e error
- Install KB3102810 update: you need to first install internet explorer and then restart your computer. You need to install the KB3102810 update if you have not installed it yet. Once you update it, you need to rebuild the software folder.
- System files of windows need to be repaired: you need to run as an administrator and open the command prompt. Type SFC/sannow in the command prompt and press enter.
- System update readiness tools: download this tool and run this on the windows version. When completed, restart your PC.
