I am trying to update my windows but the following message appears on my screen. What I should do? “Your purchase couldn’t be completed. Something happened and your purchase can’t be completed. Windows Update error 0x80070426”
Steps To Fix Windows Update Error Ox80070426
Since there are common services that support both Windows Updates and Microsoft Store, the solutions are similar too. We will be discussing the fix for this error here.
To resolve windows update error 0x80070426, please carry out the following fix.
Run Windows Update Troubleshooter
windows update troubleshooter- To run Windows Update Troubleshooter, start by opening the Settings app from the Start Menu, and navigating to Update & Security > Troubleshooter.
Select Windows Update from the right-side panel and click on Run Troubleshooter.
Follow the on-screen instructions to troubleshoot the issue that you are facing.
