Steps To Install And Configure Cactiez Iso
What is cactiez iso? How can I install and configure cactiez iso? What are the data sources and graphs in cacti?
Cacti is a whole system graphing resolution designed to control the compulsion of RRDTool’s data room and graphing functionality. Cacti implement forward graph templating, multiple data purchase methods, and user authority features. All of this is encircled in a natural, easy to use interface that makes sense for LAN-sized connections up to complicated networks with thousands of machines.
To install and configure cactiez iso you need to first download it.
Then extract and burn the cd image.
once it is done the installation will take place then you need to login into cacti whose default username and password is admin once logged in you will be configuring the router to collect all the SNMP statistics.
Data sources mean data is gathered from various sources and stored in a database such as MySQL. Data sources can be used to plot several pieces of information on the diagram. And the design means you can create any imaginable graphs considering the data which has been collected. RRD Tool can be used for the creation of graphs.
