Steps To Learn How To Convert Pdf File To XML Format
Hey! I wish to know how to convert PDF file to XML. Please instruct me on how to get an XML file from PDF format and reply soon!
Hey! You can convert the pdf file to XML format online or offline. Online, you can convert using many websites such as onlineconvertfree. Just upload the file by clicking on Choose File. Browse and select the file to be uploaded. Download the received file. Offline, you can get XML format using Adobe Acrobat Reader.
First, open the file in Adobe Reader. Select Export and select XML from there. Name the file and using save in option, select the location where the file needs to be saved. Find the location of file and launch the converted file by clicking on it. I hope this helps in understanding how to convert pdf file to XML format.
