Steps To Remove Welcome Screen Windows 7
Hi! I want to ‘remove welcome screen Windows 7.’ It is very annoying. Can you please mention the steps to remove it?
To ‘remove welcome screen Windows 7’ you can follow the steps mentioned below-
If you are getting annoyed of the welcome screen in Windows 7, there are ways to disable it but not remove it depending on what edition you are using. There are six (6) editions of Windows 7 and only three are available in retail: Home Premium, Professional, and Ultimate. The remaining three editions were not available in retail: Starter, Home Basic, and Enterprise.
If you have Windows 7 Professional or Ultimate, you can use the Group Policy Editor to disable the welcome screen. Press the Windows key + R to bring up the “Run” dialog then type without quotes “gpedit.msc” and then hit Enter. In “Group Policy” window, go to or expand “Computer Configuration,” “Windows Settings,” “Security Settings,” “Local Policies” then “Security Options.”
On the right pane, locate and double-click “Interactive logon: Do not display last user name” to open the “Properties.” Or right-click “Interactive logon: Do not display last user name” and select “Properties.” In the properties window, in “Local Security Setting” tab, select “Enabled” then click “OK.” Restart the computer when you are finished.
If you have Windows 7 Home Premium, by default, the Group Policy Editor is not available. Instead, you can use the registry editor. Press the Windows key + R to bring up the “Run” dialog then type without quotes “regedit” and then hit Enter. In the “Registry Editor” window, navigate to the following location:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
On the right pane, locate and double-click “dontdisplaylastusername.” Change “Value data” to without quotes “1” then click “OK.” Restart the computer when you are finished.
