Steps To Setup Windows Photo Viewer Software
Hi, after I updated my windows version, some new software for viewing photos is set. I want the old windows photo viewer software. Can you please help me with the steps?
It is easy to get the trustworthy old windows photo viewer back – simply open settings and go to system > default apps. Under “photo viewer, you should see your current default photo viewer (probably the new photos app ). Click this to see a list of options for a new default photo viewer. Assuming you upgraded to windows 10 from a previous version of windows, you should see windows photo viewer as an option
Choose windows photo viewer and exit the settings menu, and you are done.
