Hello, since last few days I have been uninstalling all the application which I do not use on my laptop. I am using a different browser right now due to which I have not used Internet Explorer 8 for many months. I have uninstalled many applications, but I could not find any option to uninstall Internet Explorer 8 from my PC. Help me with this. Thank you in advance.
Steps to uninstall Internet Explorer 8.
Open Control Panel by typing ‘Control Panel’ in the Search Bar of Start Menu of your PC, and clicking on the desired icon. Now, click on ‘Uninstall a program.’
Now, click on ‘Turn Windows features on or off’ situated on the left side of the Programs and Features Tab. A new dialog box will appear. To uninstall Internet Explorer 8, clear the ‘Check Box’ of the Internet Explorer 8 by clicking on it and then click ‘OK.’ A new dialog box will appear, which will ask, ‘Do you want to continue?’ Select ‘Yes.’ Within a few seconds, a new dialog box will appear which will ask you to restart your laptop, click on ‘Restart Now.’ Your laptop will now restart. Internet Explorer 8 is successfully uninstalled in this way.
