Steps To Use Microsoft Office Click To Run
I was installing the Microsoft office suite and was shown the option of Microsoft Office click to run, can anyone help me out with this issue that what should I do next to install the suite in my laptop.
Hi! I understand your query so, Microsoft Office Click-to-Run is an alternate installation type for Microsoft Office products that utilize streaming and virtualization technology to reduce the time required to install Office and help run multiple versions of Office on the same computer.
To determine if you have a Click-to-Run installation of Microsoft Office:
Option I: In Microsoft Outlook
In your Microsoft Excel, Word, or Outlook 2013 or 2016 application select File, then Office Account then select About Outlook select (in Microsoft Outlook 2010 choose File, and then select Help)
On the right side of the screen, locate About Microsoft.
If the installed release of the Office product is a Click-to-Run edition, the text will include Click-to-Run.
Option II: In Control Panel
On the keyboard press Windows+R keys.
Type control panel.
Click OK.
Select Programs and Features.
Select Microsoft Office.
Right-click Microsoft Office, and then click on Change.
If it shows “How would you like to repair your Office programs?” and has two options to do Quick Repair or Online Repair, then it is the Click-to-Run version.
I hope you have understood what to do with this feature.
