Steps You Need For My Ipod Touch Won’t Turn On And Its Solutions.
Hello, I am facing a problem with my iPod touch won’t turn on notify me the stepwise solution for the same for the easy understanding . Thank you for the same.
Hello, below show the solutions for my iPod touch won’t turn on in stepwise are as follows:
• First make sure your hands are clean and dry
• Next if there sandy screen guard or the protector on the device try removing it
• Now you have to clean the screen with soft cloth to every corner and in the middle wisely
• Next you just have to unplug the device carefully
• Next restart your device or can do force start if it’s not possible
Thanks for the answer.. Very helpful….
