Stereo audio files to be convert to 8 bit mono in .net
Hi All,
I need few stereo audio files to be convert to 8 bit mono in .net, How should I do the same, Please help me by getting inputs on this regard. Waiting to hear from experts,
Thank You,
Annarforster
Answered By 5 points N/A #198680
Hey Mr. Annarfoster,
There are two steps in audio conversion: 1. Decoding and 2. Encoding.
Logically, we will first need to decode the audio to PCM and then encode to required format.
Well, converting stereo to mono is very simple. We know that stereo has 2 samples-left and right. Discarding any one of them will give us mono audio format.
Here is the code you need:(We are discarding the right channel)
private byte[] StereoToMono(byte[] input)
    byte[] output = new byte[input.Length / 2]; //to discard input length
    int outputIndex = 0;
    for (int n = 0; n < input.Length; n+=4)
        // copy in the first 16 bit sample
        output[outputIndex++] = input[n];
        output[outputIndex++] = input[n+1];
    return output;
Method 2:
Alternatively, we can try mixing the two samples together:
(I have used Bitconverter function and every two bytes are converted to Int16)
private byte[] MixStereoToMono(byte[] input)
        int leftChannel = BitConverter.ToInt16(input,n);
        int rightChannel = BitConverter.ToInt16(input,n+2);
        int mixed = (leftChannel + rightChannel) / 2;
        byte[] outSample = BitConverter.GetBytes((short)mixed);
        output[outputIndex++] = outSample[0];
        output[outputIndex++] = outSample[1];
    return output;
Let me know if this helps.
