Stick notes windows explorer for 7 only?
I am still using Windows XP. Is stick notes windows explorer for the version 7 only? I like writing my thoughts and ideas while working on a blog and this would be helpful for me. Is it possible to have it in XP. If yes, where can I have it downloaded?
Best Answer by Baker Martin
Answered By 0 points N/A #144129
Dear Edward,
I hope you are doing well, anyway moving on to your query, yes you can get it from the link below.
http://www.7stickynotes.com/help/installation.php
The procedure is also mentioned in the link, as well for your portable devices.
I wish you all the best.
Kurtt
Answered By 5 points N/A #144131
Dear user,
For using sticky noted on Windows XP, you can download Notezilla. It can work on Windows 8, Windows 7, Windows Vista and on Windows XP (Both 32 bit & 64 bit). Through this software, you can also stick these notes to any website or any program. You can also download 7 Sticky Notes software, it works with Windows XP.
Hope this will help you.
Thank you.
Answered By 0 points N/A #144133
Hi there,
Yes, you can also use the sticky notes even in windows XP operating system. There are lots of different sites where you can download your sticky notes.
Stick notes is a very useful tool to us, that’s why lots of people using it find it very helpful.
It lets you store quick information, it is organize, lets you search and store priorities and alarms. And it also sets as your reminder.
You can download it here: http://download.cnet.com/Sticky-Notes/3000-12565_4-10573348.html
It is good to have a sticky note.
