Isabellartd
70 points
Posted on - 11/06/2012
Hey guys. I am looking for a post it for pc application or utility which can help me minimize the yellow notes which I always stick on to my monitor. Does anybody know of anything similar, like a computerized version of this note? Thanks a bunch!
sephsef
Sticky Notes Utilities or PC Application for Windows
I suggest you get a Post-it Digital Notes. It is like using an ordinary post-it but is packed with great features to keep you organized.
–         Easy to use.
–         You can make a list or reminders.
–         Colour coded notes.
–         Can sort them by categories.
–         Can group in memo boards or folders.
–         Set alarms to remind yourself of appointments and projects.
–         You can send notes via Email or LAN to contacts.
I hope this helps.
