Stock Browser lagging and rebooting my HTC ONE S
From a couple of days whenever I open the stock browser on my HTC ONE S, my phone start lagging and ultimately reboots my device. I have factory reset the phone but the problem still persist.
How do I resolve this? I have been too much dependent on the stock browser.
Answered By 590495 points N/A #154122
If you already factory reset your mobile phone and still nothing happened, maybe the problem is with the device and not with the installed applications.
Check again the available physical memory of the phone and then see if it’s enough to open another application. I suspect that your phone has only too little memory left which is not enough to open another application.
Maybe that’s also one of the reasons why it keeps on rebooting every time you open or launch the stock browser.
You may try adding more memory to your mobile phone so that your device doesn’t have a hard time balancing or handling its total memory load. Avoid also installing too much application on the phone’s physical memory.
If ever you’ll be installing new applications on the device, install it on an external memory like for example a micro SD card.
